Rz vs Ra roughness
Read articleYou’ve come to the right place. Hubs is now Protolabs Network.
The same broad capabilities, exceptional quality and competitive pricing under a new brand.
EN
Use these conversion tables of standard drill bit sizes (metric, fractional inch, and wire gauge) common in CNC machining to reduce manufacturing costs from custom tooling.
Custom tooling can quickly increase your manufacturing costs. Knowing how to get the most out of standard tooling can save you a significant amount of money on producing custom parts.
To reduce the need for custom tooling, we have created these three tables to summarize the standard drill bit sizes used in CNC machining.
The three tables below provide standard, fractional inch and wire gauge drill bit sizes. It's helpful, and often essential, to match these standard sizes when designing CNC parts with drill holes.
If you design holes that don't fit into these ranges, you may need specialized tooling to manufacture your parts.
Want to learn more about CNC machining?
Drill size | Diameter (in) |
0.05 mm | 0.0020 |
0.1 mm | 0.0039 |
0.2 mm | 0.0079 |
0.3 mm | 0.0118 |
0.4 mm | 0.0158 |
0.5 mm | 0.0197 |
0.6 mm | 0.0236 |
0.7 mm | 0.0276 |
0.8 mm | 0.0315 |
0.9 mm | 0.0354 |
1 mm | 0.0394 |
1.1 mm | 0.0433 |
1.2 mm | 0.0472 |
1.3 mm | 0.0512 |
1.4 mm | 0.0551 |
1.5 mm | 0.0591 |
1.6 mm | 0.0630 |
1.7 mm | 0.0669 |
1.8 mm | 0.0709 |
1.9 mm | 0.0748 |
2 mm | 0.0787 |
2.1 mm | 0.0827 |
2.2 mm | 0.0866 |
2.3 mm | 0.0906 |
2.4 mm | 0.0945 |
2.5 mm | 0.0984 |
2.6 mm | 0.1024 |
2.7 mm | 0.1063 |
2.8 mm | 0.1102 |
2.9 mm | 0.1142 |
3 mm | 0.1181 |
3.1 mm | 0.1221 |
3.2 mm | 0.1260 |
3.3 mm | 0.1299 |
3.4 mm | 0.1339 |
3.5 mm | 0.1378 |
3.6 mm | 0.1417 |
3.7 mm | 0.1457 |
3.8 mm | 0.1496 |
3.9 mm | 0.1535 |
4 mm | 0.1575 |
4.1 mm | 0.1614 |
4.2 mm | 0.1654 |
4.3 mm | 0.1693 |
4.4 mm | 0.1732 |
4.5 mm | 0.1772 |
4.6 mm | 0.1811 |
4.7 mm | 0.1850 |
4.8 mm | 0.1890 |
4.9 mm | 0.1929 |
5 mm | 0.1969 |
5.1 mm | 0.2008 |
5.2 mm | 0.2047 |
5.3 mm | 0.2087 |
5.4 mm | 0.2126 |
5.5 mm | 0.2165 |
5.6 mm | 0.2205 |
5.7 mm | 0.2244 |
5.8 mm | 0.2284 |
5.9 mm | 0.2323 |
6 mm | 0.2362 |
6.1 mm | 0.2402 |
6.2 mm | 0.2441 |
6.3 mm | 0.2480 |
6.4 mm | 0.2520 |
6.5 mm | 0.2559 |
6.6 mm | 0.2598 |
6.7 mm | 0.2638 |
6.8 mm | 0.2677 |
6.9 mm | 0.2717 |
7 mm | 0.2756 |
7.1 mm | 0.2795 |
7.2 mm | 0.2835 |
7.3 mm | 0.2874 |
7.4 mm | 0.2913 |
7.5 mm | 0.2953 |
7.6 mm | 0.2992 |
7.7 mm | 0.3032 |
7.8 mm | 0.3071 |
7.9 mm | 0.3110 |
8 mm | 0.3150 |
8.1 mm | 0.3189 |
8.2 mm | 0.3228 |
8.3 mm | 0.3268 |
8.4 mm | 0.3307 |
8.5 mm | 0.3347 |
8.6 mm | 0.3386 |
8.7 mm | 0.3425 |
8.8 mm | 0.3465 |
8.9 mm | 0.3504 |
9 mm | 0.3543 |
9.1 mm | 0.3583 |
9.2 mm | 0.3622 |
9.3 mm | 0.3661 |
9.4 mm | 0.3701 |
9.5 mm | 0.3740 |
9.6 mm | 0.3780 |
9.7 mm | 0.3819 |
9.8 mm | 0.3858 |
9.9 mm | 0.3898 |
10 mm | 0.3937 |
10.5 mm | 0.4134 |
11 mm | 0.4331 |
11.5 mm | 0.4528 |
12 mm | 0.4724 |
12.5 mm | 0.4921 |
13 mm | 0.5118 |
13.5 mm | 0.5315 |
14 mm | 0.5512 |
14.5 mm | 0.5709 |
15 mm | 0.5906 |
15.5 mm | 0.6102 |
16 mm | 0.6299 |
16.5 mm | 0.6496 |
17 mm | 0.6693 |
17.5 mm | 0.6890 |
18 mm | 0.7087 |
18.5 mm | 0.7284 |
19 mm | 0.7480 |
19.5 mm | 0.7677 |
20 mm | 0.7874 |
20.5 mm | 0.8071 |
21 mm | 0.8268 |
21.5 mm | 0.8465 |
22 mm | 0.8661 |
22.5 mm | 0.8858 |
23 mm | 0.9055 |
23.5 mm | 0.9252 |
24 mm | 0.9449 |
24.5 mm | 0.9646 |
25 mm | 0.9843 |
25.5 mm | 1.0039 |
26 mm | 1.0236 |
26.5 mm | 1.0433 |
27 mm | 1.0630 |
27.5 mm | 1.0827 |
28 mm | 1.1024 |
28.5 mm | 1.1221 |
29 mm | 1.1417 |
29.5 mm | 1.1614 |
30 mm | 1.1811 |
30.5 mm | 1.2008 |
31 mm | 1.2205 |
31.5 mm | 1.2402 |
32 mm | 1.2598 |
32.5 mm | 1.2795 |
33 mm | 1.2992 |
33.5 mm | 1.3189 |
34 mm | 1.3386 |
34.5 mm | 1.3583 |
35 mm | 1.3780 |
35.5 mm | 1.3976 |
36 mm | 1.4173 |
36.5 mm | 1.4370 |
37 mm | 1.4567 |
37.5 mm | 1.4764 |
38 mm | 1.4961 |
Drill size | Diameter (in) | Diameter (mm) |
1/64 in | 0.0156 | 0.3969 |
1/32 in | 0.0313 | 0.7938 |
3/64 in | 0.0469 | 1.1906 |
1/16 in | 0.0625 | 1.5875 |
5/64 in | 0.0781 | 1.9844 |
3/32 in | 0.0938 | 2.3813 |
7/64 in | 0.1094 | 2.7781 |
1/8 in | 0.1250 | 3.1750 |
9/64 in | 0.1406 | 3.5719 |
5/32 in | 0.1563 | 3.9688 |
11/64 in | 0.1719 | 4.3656 |
3/16 in | 0.1875 | 4.7625 |
13/64 in | 0.2031 | 5.1594 |
7/32 in | 0.2188 | 5.5563 |
15/64 in | 0.2344 | 5.9531 |
1/4 in | 0.2500 | 6.3500 |
17/64 in | 0.2656 | 6.7469 |
9/32 in | 0.2813 | 7.1438 |
19/64 in | 0.2969 | 7.5406 |
5/16 in | 0.3125 | 7.9375 |
21/64 in | 0.3281 | 8.3344 |
11/32 in | 0.3438 | 8.7313 |
23/64 in | 0.3594 | 9.1281 |
3/8 in | 0.3750 | 9.5250 |
25/64 in | 0.3906 | 9.9219 |
13/32 in | 0.4063 | 10.3188 |
27/64 in | 0.4219 | 10.7156 |
7/16 in | 0.4375 | 11.1125 |
29/64 in | 0.4531 | 11.5094 |
15/32 in | 0.4688 | 11.9063 |
31/64 in | 0.4844 | 12.3031 |
1/2 in | 0.5000 | 12.7000 |
33/64 in | 0.5156 | 13.0969 |
17/32 in | 0.5313 | 13.4938 |
35/64 in | 0.5469 | 13.8906 |
9/16 in | 0.5625 | 14.2875 |
37/64 in | 0.5781 | 14.6844 |
19/32 in | 0.5938 | 15.0813 |
39/64 in | 0.6094 | 15.4781 |
5/8 in | 0.6250 | 15.8750 |
41/64 in | 0.6406 | 16.2719 |
43/64 in | 0.6719 | 17.0656 |
11/16 in | 0.6875 | 17.4625 |
45/64 in | 0.7031 | 17.8594 |
23/32 in | 0.7188 | 18.2563 |
47/64 in | 0.7344 | 18.6531 |
3/4 in | 0.7500 | 19.0500 |
49/64 in | 0.7656 | 19.4469 |
25/32 in | 0.7813 | 19.8438 |
51/64 in | 0.7969 | 20.2406 |
13/16 in | 0.8125 | 20.6375 |
53/64 in | 0.8281 | 21.0344 |
27/32 in | 0.8438 | 21.4313 |
55/64 in | 0.8594 | 21.8281 |
7/8 in | 0.8750 | 22.2250 |
57/64 in | 0.8906 | 22.6219 |
29/32 in | 0.9063 | 23.0188 |
21/23 in | 0.9130 | 23.1913 |
59/64 in | 0.9219 | 23.4156 |
15/16 in | 0.9375 | 23.8125 |
61/64 in | 0.9531 | 24.2094 |
31/32 in | 0.9688 | 24.6063 |
63/64 in | 0.9844 | 25.0031 |
1 in | 1.0000 | 25.4000 |
1 1/64 in | 1.0156 | 25.7969 |
1 1/32 in | 1.0313 | 26.1938 |
1 3/64 in | 1.0469 | 26.5906 |
1 1/16 in | 1.0625 | 26.9875 |
1 5/64 in | 1.0781 | 27.3844 |
1 3/32 in | 1.0938 | 27.7813 |
1 7/64 in | 1.1094 | 28.1781 |
1 1/8 in | 1.1250 | 28.5750 |
1 9/64 in | 1.1406 | 28.9719 |
1 5/32 in | 1.1563 | 29.3688 |
1 11/64 in | 1.1719 | 29.7656 |
1 3/16 in | 1.1875 | 30.1625 |
1 13/64 in | 1.2031 | 30.5594 |
1 7/32 in | 1.2188 | 30.9563 |
1 15/64 in | 1.2344 | 31.3531 |
1 1/4 in | 1.2500 | 31.7500 |
1 17/64 in | 1.2656 | 32.1469 |
1 9/32 in | 1.2813 | 32.5438 |
1 19/64 in | 1.2969 | 32.9406 |
1 5/16 in | 1.3125 | 33.3375 |
1 21/64 in | 1.3281 | 33.7344 |
1 11/32 in | 1.3438 | 34.1313 |
1 23/64 in | 1.3594 | 34.5281 |
1 3/8 in | 1.3750 | 34.9250 |
1 25/64 in | 1.3906 | 35.3219 |
1 13/32 in | 1.4063 | 35.7188 |
1 27/64 in | 1.4219 | 36.1156 |
1 7/16 in | 1.4375 | 36.5125 |
1 29/64 in | 1.4531 | 36.9094 |
1 15/32 in | 1.4688 | 37.3063 |
1 31/64 in | 1.4844 | 37.7031 |
1 1/2 in | 1.5000 | 38.1000 |
Ready to produce complex, custom parts for your project?
#107 | 0.0019 | 0.0483 |
#106 | 0.0023 | 0.0584 |
#105 | 0.0027 | 0.0686 |
#104 | 0.0031 | 0.0787 |
#103 | 0.0035 | 0.0889 |
#102 | 0.0039 | 0.0991 |
#101 | 0.0043 | 0.1092 |
#100 | 0.0047 | 0.1194 |
#99 | 0.0051 | 0.1295 |
#98 | 0.0055 | 0.1397 |
#97 | 0.0059 | 0.1499 |
#96 | 0.0063 | 0.1600 |
#95 | 0.0067 | 0.1702 |
#94 | 0.0071 | 0.1803 |
#93 | 0.0075 | 0.1905 |
#92 | 0.0079 | 0.2007 |
#91 | 0.0083 | 0.2108 |
#90 | 0.0087 | 0.2210 |
#89 | 0.0091 | 0.2311 |
#88 | 0.0095 | 0.2413 |
#87 | 0.0100 | 0.2540 |
#86 | 0.0105 | 0.2667 |
#85 | 0.0110 | 0.2794 |
#84 | 0.0115 | 0.2921 |
#83 | 0.0120 | 0.3048 |
#82 | 0.0125 | 0.3175 |
#81 | 0.0130 | 0.3302 |
#80 | 0.0135 | 0.3429 |
#79 | 0.0145 | 0.3680 |
#78 | 0.0160 | 0.4064 |
#77 | 0.0180 | 0.4572 |
#76 | 0.0200 | 0.5080 |
#75 | 0.0210 | 0.5334 |
#74 | 0.0225 | 0.5715 |
#73 | 0.0240 | 0.6096 |
#72 | 0.0250 | 0.6350 |
#71 | 0.0260 | 0.6604 |
#70 | 0.0280 | 0.7112 |
#69 | 0.0292 | 0.7417 |
#68 | 0.0310 | 0.7874 |
#67 | 0.0320 | 0.8128 |
#66 | 0.0330 | 0.8382 |
#65 | 0.0350 | 0.8890 |
#64 | 0.0360 | 0.9144 |
#63 | 0.0370 | 0.9398 |
#62 | 0.0380 | 0.9652 |
#61 | 0.0390 | 0.9906 |
#60 | 0.0400 | 1.0160 |
#59 | 0.0410 | 1.0414 |
#58 | 0.0420 | 1.0668 |
#57 | 0.0430 | 1.0922 |
#56 | 0.0465 | 1.1811 |
#55 | 0.0520 | 1.3208 |
#54 | 0.0550 | 1.3970 |
#53 | 0.0595 | 1.5113 |
#52 | 0.0635 | 1.6129 |
#51 | 0.0670 | 1.7018 |
#50 | 0.0700 | 1.7780 |
#49 | 0.0730 | 1.8542 |
#48 | 0.0760 | 1.9304 |
#47 | 0.0785 | 1.9939 |
#46 | 0.0810 | 2.0574 |
#45 | 0.0820 | 2.0828 |
#44 | 0.0860 | 2.1844 |
#43 | 0.0890 | 2.2606 |
#42 | 0.0935 | 2.3749 |
#41 | 0.0960 | 2.4384 |
#40 | 0.0980 | 2.4892 |
#39 | 0.0995 | 2.5273 |
#38 | 0.1015 | 2.5781 |
#37 | 0.1040 | 2.6416 |
#36 | 0.1065 | 2.7051 |
#35 | 0.1100 | 2.7940 |
#34 | 0.1110 | 2.8194 |
#33 | 0.1130 | 2.8702 |
#32 | 0.1160 | 2.9464 |
#31 | 0.1200 | 3.0480 |
#30 | 0.1285 | 3.2639 |
#29 | 0.1360 | 3.4544 |
#28 | 0.1405 | 3.5687 |
#27 | 0.1440 | 3.6576 |
#26 | 0.1470 | 3.7338 |
#25 | 0.1495 | 3.7973 |
#24 | 0.1520 | 3.8608 |
#23 | 0.1540 | 3.9116 |
#22 | 0.1570 | 3.9878 |
#21 | 0.1590 | 4.0386 |
#20 | 0.1610 | 4.0894 |
#19 | 0.1660 | 4.2164 |
#18 | 0.1695 | 4.3053 |
#17 | 0.1730 | 4.3942 |
#16 | 0.1770 | 4.4958 |
#15 | 0.1800 | 4.5720 |
#14 | 0.1820 | 4.6228 |
#13 | 0.1850 | 4.6990 |
#12 | 0.1890 | 4.8006 |
#11 | 0.1910 | 4.8514 |
#10 | 0.1935 | 4.9149 |
#9 | 0.1960 | 4.9784 |
#8 | 0.1990 | 5.0546 |
#7 | 0.2010 | 5.1054 |
#6 | 0.2040 | 5.1816 |
#5 | 0.2055 | 5.2197 |
#4 | 0.2090 | 5.3086 |
#3 | 0.2130 | 5.4102 |
#2 | 0.2210 | 5.6134 |
#1 | 0.2280 | 5.7912 |
A | 0.2340 | 5.9436 |
B | 0.2380 | 6.0452 |
C | 0.2420 | 6.1468 |
D | 0.2460 | 6.2484 |
E | 0.2500 | 6.3500 |
F | 0.2570 | 6.5278 |
G | 0.2610 | 6.6294 |
H | 0.2660 | 6.7564 |
I | 0.2720 | 6.9088 |
J | 0.2770 | 7.0358 |
K | 0.2810 | 7.1374 |
L | 0.2900 | 7.3660 |
M | 0.2950 | 7.4930 |
N | 0.3020 | 7.6708 |
O | 0.3160 | 8.0264 |
P | 0.3230 | 8.2042 |
Q | 0.3320 | 8.4328 |
R | 0.3390 | 8.6106 |
S | 0.3480 | 8.8392 |
T | 0.3580 | 9.0932 |
U | 0.3680 | 9.3472 |
V | 0.3770 | 9.5758 |
W | 0.3860 | 9.8044 |
X | 0.3970 | 10.0838 |
Y | 0.4040 | 10.2616 |
Z | 0.4130 | 10.4902 |
Learn how to cut CNC machining costs by 50%
Read articleLearn about the role quality documentation plays in the manufacturing process, how to obtain it, and the types of documentation that apply to parts, materials, and more
Read articleWhat is Delrin and why is it unique among the many manufacturing materials available? Delrin, or POM-H (homopolymer acetal), is used in CNC machining, 3D printing and injection molding to create durable, precise components. This article explores Delrin’s properties and how to get the most out of the material.
Read articleWhat is CNC milling and how does this subtractive manufacturing process work? This article explores how CNC milling machines work, what kinds of parts you can provide with milling and the best design practices for getting the most out of this type of CNC machining.
Read articleHow do you add logos, lettering, serial numbers and other customized designs to your custom parts? Part marking is a cost-effective way to give parts those extra identifying and/or cosmetic details. Learn the common part marking techniques on the market today, including laser engraving and silk screening.
Read articleWhat are the different types of threads for manufacturing? In this article, learn how to correctly design threads to reduce lead times and cost for your next CNC machining production run.
Read articleTables of the standard blank sizes (sheets & rods) commonly used in CNC machining.
Read articleHow do you prepare technical drawings for CNC machining and why are they important? Technical drawings are widely used in manufacturing to improve the communication of technical requirements between the designer and engineer and the manufacturer.
Read articleWhat is CNC machining and how does it work? Learn the basic principles and fundamental mechanics, as well as the key benefits and limitations, of this subtractive manufacturing process.
Read articleUse these conversion tables of standard drill bit sizes (metric, fractional inch, and wire gauge) common in CNC machining to reduce manufacturing costs from custom tooling.
Read articleWhat surface finishes are available for CNC machining? You can apply post-processing and surface finishes to improve the surface roughness, cosmetic properties and wear resistance of metal parts. Learn about the most common ways to finish CNC machined parts, and how to select the best methods for your applications.
Read articleRz and Ra are measurements used to describe and quantify surface roughness in manufacturing and engineering. Find out more about these different ways of measuring roughness as a machining finish for custom parts.
Read articleShow more
